2008 te510 fuel injector replacement... or carb swap
Discussion in 'EFI/carb' started by Kessig4x4, Sep 4, 2021.
  1. Kessig4x4 Husqvarna
    Te510
    76 Harley
    I have a 2008 TE510 which over the past few years has given me an abundance of efi problems. This weeks issue is that the fuel injector is functioning improperly. I wiuld have to imagine its getting stuck as it will just pour fuel out and load the cylinder/exhaust with fuel. I took it apart and there where streams coming outbof it, i eventually gotbit to clear up and act correctly and than moments later of riding it it did the same thing. I am having trouble finding a replacement injector for it. Does anyone have a source for this?
    I would also greatly entertain the idea of putting a carburaetor on it so i could trust the bike but not sure how that would effect my ignition system. I have had the fuel pump/injector leave me stranded before and am uncomfortable going anywhere on the bike by myself.
    Thankyou
  2. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    What’s the condition of your fuel filter? And how have you cleaned your injector? Have you cleaned it both directions?
  3. Kessig4x4 Husqvarna
    Te510
    76 Harley
    I havent done anything special to clean the injector, tomorrow i should actually get some free time to work on it and i will try cleaning it out and riding around the property for a bit and see if it sticks again. The filter is pretty new as i just replaced the pump recently, however it will not hurt to take a look/replace it. I have also only ran high quality fuel from the same clean can through it but theres always the chance aomething got in it. Not having much luck locating a new injector i will see if i can find any kind of number off it and maybe get it from a retailer for the injector manufacturer. Unless i find something thats definately the issue and definately resolved i dont think id be comfortable taking the bike out on any substantial ride with it potentially bound to stick again.
    268fords likes this.
