Has anyone seen this before? My 06 does not start and my mechanic has performed the following: "At this point here is what I have done Motorcycle will not start or even try Between tests I would check to see if I made a change to the issue Checked spark - strong and blue Checked for fuel for water/bad fuel in the carburetor - Had clean healthy fuel, no sign of water Checked for loose clamps and or vacuum leaks - None found Perform leak down test - 7% loss Removed flywheel to check for a sheered woodruff key - No signs of damage Check resistance of pickup coil Remove carburetor and inspect and clean - no problem found Check valve clearances - both exhaust valves out of spec, but only by a couple of tenths, not enough to hold a valve open. Also inspected the decompression actuator, seems fine and moves freely while still returning to activate the decompression. I did change the shims on the exhaust valves since I was already there. If anyone has seen something like this, I would greatly appreciate any advice available Calling a priest to perform an Exorcism has been considered. " Much appreciated for any insight! Cheers!
i would call george at up-tite racing in santa ana ca. knows more then anybody in the country on huskys. was the oldest dealer untill a few years ago. my .02
