125-200cc 2002 cr 250 steering head washer
Discussion in '2 Stroke' started by bulto, Jun 25, 2022.
  1. bulto Husqvarna
    2002 cr 250
    ktm maico honda
    Does anyone know proper location of the washer in the steering head? Thanks.
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    are you taking about where it fits with the steering bearings?
    if so, in the assembly it fits on top of the upper bearing then the nut goes on top then the upper triple clamp then the final nut
  3. bulto Husqvarna
    2002 cr 250
    ktm maico honda
    Yes thats the washer. I found it in my parts washer so I wasn't sure. Ok then on top of bearing, then seal and nut with flange facing down then clamp! Thanks Premo.
  4. 2premo Husqvarna
    Northern NV
    I forgot those have a separate top seal, it might go on top of the seal, it will be obvious if the bearing is in and there is only room for the seal to the frame the washer goes on top if you place the washer first and the seal has a gap to the frame, hope you get what i mean there
  5. bulto Husqvarna
    2002 cr 250
    ktm maico honda
    Thanks for the info .I will check the seal location to the frame.
  6. Sonnie Mee Husqvarna
    England
    Team Motorex Husqvarna CR125
    Everyone we ever take off is wrong sometimes the washer is on 1st, sometimes it’s on the top of the top seal, sometimes it’s on top of the ring nut all wrong
    Correct way in order from bottom triple clamp to top
    1st seal
    2nd washer
    3rd bottom bearing
    Slide the clamp and steering stem into frame head stock
    4th top bearing
    5th top seal
    6th ring nut
    7th top clamp
    8th retaining but
    Hope that helps
  7. bulto Husqvarna
    2002 cr 250
    ktm maico honda
    Sonny ,that makes sense since I didn't see washer until I found it in parts washer. It was on bottom clamp. If I want put it correct I have to pull my new bearing off bottom clamp again. That sucks! Thank you for your time to set it straight, Al
  8. Sonnie Mee Husqvarna
    England
    Oh no sorry to hear that it’s a bit of a pain we usually press the pin out and back in to save destroying the new bearing but usually we are scrapping the bearing so we cut the rollers off and use motion pro puller
  9. rancher1 Husqvarna
    WA
    I have forgot the washer before, the bearings will not tighten up with out it. It was a bummer to remove the bearing from the stem. I usually put the washer on first now but most of my work has been with the enduro style bearings that have the seal incorporated on the bearing.
  10. bulto Husqvarna
    2002 cr 250
    ktm maico honda
    I was thinking that husky kinda screwed this up. The correct way is what Sonny is saying but that means less seal around bearing but it's only 040 thousands. I guess washer first ain't a bad idea. Just wondering if putting washer on top of upper seal is all that bad? Any comments? Thanks guy's you really help.
