I'm having a rear wheel spacer issue with this nightmare of a TE610 I'm currently fettling. The rear wheel spacers don't seem to be correct. The parts list shows them as identical items on each side but I have 8mm one on the disc side and a 20.5mm one on the Sprocket side. I'm also left with a gap when it's all assembled. Can anyone measure up what they have and I'll get some machined up. The bike is a 2001 left kickstart model with solid mounted sprocket (no cush drive). TIA
Hi, I have a 2001 TE570, The wheel spacers, part 12 in the parts list are both 17mm thick, I just took them out to measure. One problem in the parts list, part 10, the bearing on the brake disc side should be a 63005 - 2RS, 25 x 47 x 16mm. The parts list shows it as 12mm wide (wrong!) Cheers, Dave.
Thanks Dave, would that be part no. 8000 92414? if so that would take up 5.5mm of gap I have which I think would be correct.
Hi, Can you check your compliance plate for month/year of manufacture? Looking on E-bay there is a pic of a 2000 rear axle with spacers that are not the same size. http://www.ebay.com/itm/2000-00-Hus...R-WHEEL-AXLE-WITH-SPACERS-/230850678361?hash= I seem to remember my 95 360 had different size spacers. Is your bearing on the disc side 12mm wide or 16mm wide? Someone else on this forum, bought a All Balls Bearing kit which had the wrong width bearing for the brake disc side. That part number you gave me is for the longest spacer in the rear hub. Cheers, Dave.
Well the plots thickening on this one! I've checked my model year by VIN and that seems correct at 2000 (ZCGH601AAYV005541) Looking more closely at my wheel and at the corresponding parts list I can only assume the wheel is incorrect for the model. The bearing seal sizes on each sided are different (they should be identical) and on the sprocket side the bearings are retained by a castellated nut instead of just being a press fit. Also my disc has 6 retaining bolts instead of 4. Looking through some other parts lists it seems to relate to an earlier model TC 610. It's no issue I'll just have to do some accurate measuring and get some custom spacers made. Thanks for your help!
