250-500cc 1996 WR or WXE 250 Manual
Discussion in '2 Stroke' started by joffco, Jan 20, 2018.
  1. joffco Husqvarna
    Iceland
    1996 250 WR/WXE + 1996 TE 610
    00 Yamaha YZ426 + 08 Husaberg FE450
    Hi all
    I just bought what I think is a 1996 WR or WXE 250 in boxes. I have started assembling the bike but I am stranded on several fronts. One of them is the owners or shop manual. I have done a search online but have been unable to locate one. Does anyone in here have one available in a pdf format?
    Thanks,
    Jon
  2. joffco Husqvarna
    Iceland
    Here is the unfinished project. I am missing several parts so if anyone here has a parts bike and willing to sell, I am all esrs.
    Petar likes this.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    what are you missing?
    looks like a couple of plastic pieces
  4. brian bush Husqvarna
    Colorado
    '93 WXC360, 2018 TC150
    A few KTMs and Husabergs.
    I have a number of engine parts from a 2000 WR 250. The prior owner installed a rebuilt 360 in the bike and I came away with the leftover 250 parts. I have sold some of the parts - cylinder, kickstart lever, V-Force reed valve but I still have a lot of the parts if you think any of them would work on yours. I think Husqvarna carried a lot of the parts over from year-to-year on these bikes but I am no expert on what parts fit what years unfortunately. I'd be happy to help if I can though.
    I still have a perfectly clean bottom-end that I would eat off of, clutch plates/pressure plates/basket, clutch cover, water pump cover, power valve cover, flywheel cover, rubber intake where the reeds are located, cylinder head (with 0.8mm squish mod - more low-end power), FMF Burly Pipe and various other pieces 0 feel free to ask. Let me know if you're interested in any of it and I can post pics..
    You can also find many parts on Ebaymotors.com
    Good luck with your project!
  5. joffco Husqvarna
    Iceland
    Hi 2premo
    Yes, I am missing the side panels, kickstand, chain guide (the one in the pic is worn completely through)and probably a few other things as I continue assembling.
  6. joffco Husqvarna
    Iceland
    Hi Brian
    I at least need the outer clutch basket (notched) and water pump gear (mine is missing one tooth). The head sounds interesting. I will go through the partslist and compare mine to the 2000 and let you know what fits.
    Thanks,
    Jon
  7. joffco Husqvarna
    Iceland
    Hi Brian
    I compared the parts between the 1996 and the 2000 WR:
    Clutch Basket and primary sprocket set
    1996 WR/WXE
    - 8000 64450 (250)
    - 8000 63389 (360)
    2000 WR
    - 8000 86860 (250)
    - 8000 63389 (360)
    Water pump gear
    1996 WR/WXE
    - 8000 59843 (250 & 360)
    2000 WR
    Cylinder head
    1996 WR/WXE
    - 8000 68704
    2000 WR
    - 8000 86823
    iT
    It seems that the only sure thing is the water pump gear. The other parts might fit but it is a gamble.
    Please provide pricing for these items if you are willing to part with them : )
    Thanks,
    Jon
    I
  8. joffco Husqvarna
    Iceland
    Update: Things are happening
    1C4D5B37-7352-4BD4-847D-7F84FCE58023.jpeg AF55FD1B-E5F1-486E-B460-8A9EF404D484.jpeg
  9. brian bush Husqvarna
    Colorado
    Hi Joffco, I am out of town right now. I sold a few of the 250 parts on Ebay since I last posted but I think I still have all of the items you listed. I will get you some photos and info just as soon as I can.
  10. brian bush Husqvarna
    Colorado
    I think this is the part you're looking for. $10 plus shipping in you want it..
  11. joffco Husqvarna
    Iceland
    Sold. I will send you my details via pm.
  12. brian bush Husqvarna
    Colorado
    I don't see anything in my PM. You can e-mail me at bbqkidd@yahoo.com That may be easier.. Thanks!
  13. brian bush Husqvarna
    Colorado
    Hey Joffco,
    Here are some pics of the head you asked about. It has squish cut to 1.8mm (.063"). Boosts low-end power and makes jetting easier. Likes quality gas.
  14. brian bush Husqvarna
    Colorado
    one more..
  15. 2premo Husqvarna
    Northern NV
    how far have you gotten with this??
  16. Andy butler Husqvarna
    wr 250 2011
    husaberg fe 450 yamaha xs 650 chop
    Hi Brian.
    I'm also doing and engine rebuild on a WR250. you wouldn't happen to have a crank primary gear in your spare 250 parts. 27 tooth.
    Cheers Andy
  17. joffco Husqvarna
    Iceland
    Hi all.
    Finally sat down to update this thread. Bike is up and running, have put 13 hrs on it already.
    Work done:
    New top end installed
    All oil seals and several gaskets replaced
    CR500 Keihin carb installed and jetted
    Clutch basket notches repaired
    Clutch arm lengthened
    CDI bracket fabricated and welded to frame
    Complete 2002 WR 250 electrical system installed
    Complete suspension rebuild, fwd and aft
    Shock spring powdercoated
    Retro fork boots installed
    Wheels rebuilt as required, spokes and bearings
    New brake pads fwd and back
    Front brake hose fabricated
    All frame bearings lubricated, steering, swingarm and linkage
    New handlebar bumpers, bar and grips
    LED bulbs in headlight
    Sidestand bracket fabricated and welded to frame
    Silencer core and packing replaced
    Chain guide repaired
    New chain and fwd sprocket, 13T for lower gearing
    New airfilter and cage
    New sidepanels
    Love the bike, nice torque and low end, light and agile, rear suspension great.
    Only problem is a midstroke harshness in the forks, still working on that :)
    0EE848F7-8C91-422A-8997-0B143CA97643.jpeg 0E406CBD-A8C2-4B45-8320-B5FF68799A4C.jpeg AF828132-9ED7-4A59-BD3E-07C407B68C5A.jpeg 90C4E5EF-5FF5-4CE1-BE3D-BC0A6CB61C31.jpeg
  18. joffco Husqvarna
    Iceland
    More pics :)
    E4001489-ABE9-476E-A283-436399166ED9.jpeg 636C4651-D30B-4CA8-B037-BB8581E4A019.jpeg EE5E0EE5-F52D-4545-B62B-17F12A9DDABC.jpeg
    Scott50Husky and wrx like this.
  19. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    bike looks sweet. good luck with it.
  20. Mbcoulter Husqvarna
    Central New York
    2011 Husky WR250
    Wow, fantastic pics and riding location! :cheers:
    Scott50Husky likes this.
