Hi just trying to find out some info on setting the cam timing on my te610 I have conflicting info so far as to where the cam should be when it's at TDC. There is a dot on the cam wheel one manual says to align that with the flat surface of the head and an other says align the two bolts that attach the cam wheel with the flat surface of the head. Any help I can get would be a great help.
The two bolts should be vertical, the dot should be level with the head. Either side it doesn't make a difference.
