250-500cc 1995 WR 360 parts
Discussion in '2 Stroke' started by Thomas Curran, Mar 19, 2023.
  1. Thomas Curran Husqvarna
    Buell X1 and Triumph 650
    I haven't acquired the bike yet. But Im a little concerned about engine wearable parts availability..
    Is it because it was produced by Cagiva?
    There seems too be more parts available for the 1970s Husqvarna..
    Should I tread carefully..
    I can bail out while I can
    Tell me to take a deep breath and relax
    Thanks
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    as of late the parts are more diicult to come up with
    FYI the 360 was 1992-2002
    1992 used a differs exhaust port
    92-94 is the same frame, plastic etc.
    95-99 is the same frame and plastic will interchange as well as pipe and silencer, seat etc
    00-20 share parts too
    96 or 97 the changed the porting for more low end but all parts fit
  3. Thomas Curran Husqvarna
    I am seeing that Pistons and Con Rods and bearings kits are not available if I need one..why?
    Maybe there are substitutes if I measure the parts?
    Im seeing some kits on Ebay made and shipped from Taiwan..for about 140 bucks?
    Am I not being smart? Im sure the rod itself dent usually go bad. But big and small end needle bearings probably do
    Ill keep looking on our forum for answers
  4. 2premo Husqvarna
    Northern NV
    look up Wossner pistons
    and the Taiwan rods are fine
    FYI it shares a rod with KTM, but the lower pin is longer on Husky
    Thomas Curran likes this.
  5. Thomas Curran Husqvarna
    I sent you a private conversation
    Thanks
  6. rancher1 Husqvarna
    WA
    I think wossner also makes rod kits
  7. 2premo Husqvarna
    Northern NV
    they do but not for the 360
    the KTM 380 rod is the same but the lower pin is a bit shorter on the KTM
    Royal Rods in Taiwan did make one not sure if they still do
  8. 2premo Husqvarna
    Northern NV
  9. Ghostman Husqvarna
    Portugal
    TE 450
    Brutale 990, Vespa GT200
    Hi, if you need parts for 360 I have many in stock, please send me a list in private or for my e-mail ecbike@ecbike.pt
    thanks
