250-500cc 1994 PIPE ?
Discussion in '2 Stroke' started by Saabman82, Jan 3, 2023.
  1. Saabman82 Husqvarna
    1994 wxc 250
    1978Kz650 (810),1976 kz900,1977xs650
    I NEED a new pipe for my 1994 wxc/wr250. Does anyone know of a pipe that will fit? Please!!! Ive tried dynoport but they arent even taking orders because they are so backed up. Theres got to be another aftermarket option i dont know about. Thank you
  2. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    the stock pipe on mine is double wall; very heavy.
    the headpipe diameter at the cylinder is a bit smaller than later pipes
    you might rig a later pipe and replace only the headpipe ring
  3. Saabman82 Husqvarna
    1994 wxc 250
    Not bad, i like that idea. Do you know if the mounting points match up on later pipes anf the over all pipe shape works With the frame?
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    92-94 have a similar frame, not sure what else could be cut up to work
    bore and stroke are the dimensions pipes are tuned for
  5. rancher1 Husqvarna
    WA
    The 92 pipe mounting is external on the cylinder compared to 93-94 which go inside the cylinder. I have a 1992 dyno port pipe and is different than the rest.
  6. 2premo Husqvarna
    Northern NV
    I knew that happened on the 360, but didn't on the 250
    anyways there was a comment on changing the end that fits the cylinder, is that possible?
  7. rancher1 Husqvarna
    WA
    You’re correct I don’t know why I was thinking he had a 360.
  8. 2premo Husqvarna
    Northern NV
    because we love those 360's :thumbsup:
