250-500cc 1993 CR360 ignition
Discussion in '2 Stroke' started by silverfox, Aug 7, 2023.
  1. silverfox Husqvarna
    14 te 350
    Looking for an ignition for my 93 CR 360. Bike was running but died, and now have intermittent, and weak spark. If all the planets line up it will start and run fine, but will eventually die and not refire, been through all the normal fuel reeds etc related but convinced its spark issure. what other ignitions fit? or aftermarket as no listings for an 93 CR360. Will 250 work?
  2. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Check with HPI in Belgium.
    International shipping is no problem.
    Very responsive when I needed a CDI
    silverfox likes this.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    HPI will be your best bet, good luck finding an OEM that works after 30 years
  4. brian bush Husqvarna
    Colorado
    '93 WXC360, 2018 TC150
    A few KTMs and Husabergs.
    I believe there is a stock ignition for a CR250 of that year listed on Ebay. I think it may be the same as was used on the 360 but have not pulled the parts lists to confirm. Maybe worth looking into though..
  5. 2premo Husqvarna
    Northern NV
    it has a different part number for sure
    don't know if it will work
