250-500cc 1992 Husqvrna Wxe 250
Discussion in '2 Stroke' started by Ryan529, May 7, 2024.
  1. Ryan529 Husqvarna
    1992 Husqvarna WXE 250
    1991 Ktm 250 EXC 2001 KTM 520SX
    Hello, ive just picked up a 1992 Husqvarna WXE 250 in a trade. Overall the bike in is decent condition. I got the bike and it was missing the stator nut and stator cover. The seller said it had no spark. I did a quick resistance test on the stator. I have no manuals or diagrams to work from. My stator has 3 leads all light blue. First reading was 36 Ohms second was 444 ohms and 436 ohms. The second thing i found was the ground pin in the CDI box was snapped off so i just removed the pin and making a new lead for it. Is anyone able to give me some insight on the stator and electrical system in these bikes. Anything is much appreciated.
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    what's odd it the mag looks like early Kokosan, but the coil looks like Motoplat
  3. Ryan529 Husqvarna
    The coil is motoplat and im not sure about the mag but this is how i got the bike. Does anyone know what the mag should read if its good and where does the wire go from the coil?
  4. Ryan529 Husqvarna
    Update i got a owners manual for a 1992 Husqvarna WR250 would the wiring match for the WXE?
  5. 2premo Husqvarna
    Northern NV
    yes, similar, the 92 came with Motoplat
    flyingbob likes this.
  6. Ryan529 Husqvarna
    Awsome thank you much appreciate
  7. Ryan529 Husqvarna
    I thought my boss said it was for a 1992 wr but its actually for a 2002 WR250 did they change the electrical much in these years?
  8. Ryan529 Husqvarna
    Does anyone have a headlight/killswitch for this bike for sale as well as a stator cover? As far as i can tell thats the only things missing from the bike. What is the thread for the flywheel nut as well that was take off the bike as well.
  9. 2premo Husqvarna
    Northern NV
    if it's a 2002 why on earth is there a Motoplat coil on it
    plan on n a new ignition
    the stator cover should not be hard to find, they made that engine for white a few years
  10. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Ryan529,
    If it's the bike in your avatar, that is not a 2002.
    Check your VIN to see what you really have.
    halls-cycles.com
    billshusky.com
    These guys have what you may need.
  11. Ryan529 Husqvarna
    The bike is a 1992 but the manual i was able to get was for a 2002 my apologies on the confusion.
  12. Ryan529 Husqvarna
    This is all the photos i have at the moment
  13. 2premo Husqvarna
    Northern NV
    can't tell in the pic, is the kickstand attached to the swingarm, 1992, is it attached to the frame, 1993 on
  14. Ryan529 Husqvarna
    The kickstand is attached to the swingarm.
  15. Ryan529 Husqvarna
  16. 2premo Husqvarna
    Northern NV
    definitely a late Motoplat, probably not working
    pull the plug spin with a drill see if you get voltage from the blue wire
  17. flyingbob Administrator
    USA
  18. 2premo Husqvarna
    Northern NV
  19. 2premo Husqvarna
    Northern NV
    not sure if the shaft that mounts the mag is the same taper or size, my 92 360 was different than my 93
  20. Ryan529 Husqvarna
    So i got some time today to test the stator and im getting about 15-18 volts by turning the motor over by kicker. Waiting on my new flywheel puller set to come in. Does this seem low or should i wait to pull the flywheel and test off the bike?
