TE/TC 100:1
Discussion in '2st' started by cbr929, Mar 7, 2017.
  1. cbr929 Husqvarna
    2015 FE 350 2016 TE 300
    2000 Honda cbr929 1999 Ducati 750
    Any one using Amsoil Saber Pre Mix 100:1 any feed back is welcome..
    Thinking of trying it 80:1 with my 16 TE 300
    Thanks
  2. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Is there a goal you are trying to meet?
  3. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I considered it since slavens raves about it but I chickened out and chose dominator at 50:1. I actually called Amzoil and asked them, they said don't run the weed Wacker oil in a ktm 2 stroke. Amzoil tested Dominator in a 300 in house so they safely recommend dominator. Been happy with Dominator for a couple years now. Ymmv
    JonXX, NCSteve and lankydoug like this.
  4. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    If you are trying to get it to smoke less then you need to go to a lower grade oil . One with a lower flash point .
    Not less oil .
    From the engineers at maxima
    Husky_250, NCSteve and robertaccio like this.
  5. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Amsoil Interceptor has a lower flashpoint then Dominator and keeps exhaust less oily when in putt mode. Some trials guys use Saber @100:1 but that is a very different type of use than an enduro or mx bike.
    NCSteve likes this.
  6. cbr929 Husqvarna
    Saber is JASO FD Rated, And stated in my owners manual under Standard/classification for Engine oil/2-stroke use JASO FD only use high grade 2 stroke oil of a reputable brand. JASO FD is a classification for a 2 stroke engine oil that is specifically developed or the extreme demands of racing. Thanks to first rate synthetic esters and specially designed additives, superb combustion is achieved even under extreme operating conditions.
    big change from back when I use to mix 32:1 in 85 and 89 and 2000 when I owned Honda CR's
    Seen the Slaven's racing video on oils..
  7. sethmg Husqvarna
    Owasso, OK
    2015 TE300
    Oset 12.5
    I too just saw the Slavens video, then read some threads about it on KTMtalk. My purpose or goal is to be able to carry one small bottle of it (3.5oz) on longer rides. Top off the tank with fresh fuel, add the bottle of oil, and start riding again. 3.5oz in 2.5 gallons is roughly 90:1 ratio. So close enough for my needs.
    I'm heading out to southern Utah soon for 3 days of riding and will be using it there. I'll report back on whether I blow up my bike or not!
  8. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    oil thread of the premix type. hundreds of ideas hundreds of opinions, even variables from the experts.
    me personally maxima k2 at 50:1 with safe proper jetting spec, all dry, but black out back, plugs come out with nice dark tan insulator color (safe to the slight rich side), bike pulls like a tractor.
    Husky_250, NCSteve and 87husky500xc like this.
  9. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    The real key is to pick a quality oil and stick with it.... Don't switch every time the bottle runs out, many oils don't mix right....
    I guess it all depends what your trying to achieve but I seriously don't see the point.... I want oil.... Oil is your friend....
    Yamalube 2r @50:1 for me
  10. hakkalugi Husqvarna
    North East PA
    17' TE150
    Ive been using amsoil dominator at 50:1 but saw KTM recommends anywhere from 50:1 to 100:1. Gonna try maxima out all ive ever run was amsoil see if I can tell a difference.
  11. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
  12. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Saber @ 100:1 works great in chainsaws and weed eaters, but I run 80:1 and have an old saw and weed eater that still start right up and run great after a decade of abuse. On the Saber bottle it says use more oil for racing or commercial use. Choosing pre mix ratio because of convenience doesn't seem like a good idea to me. And since AMSoil has Dominator and Interceptor don't see the point in running Saber in my bikes.
    Switched to Dominator @ 50:1 in a fresh 165. 35 hours in now and no loss of compression or performance, minimal smoke and spooge. I don't putt or trail ride it much, WFO 90% of the time. Will be interesting to see the wear when I freshen it up next.
    :cheers:
  13. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Take 2 small bottles?!! Not sure how keen I'd be on running anymore than 1/4-1/2 throttle at 90-100:1
  14. NH-JP 2nd Fastest Old, Slow Guy!
    New Hampshire
    2017 TE300
    1988 Honda Hurricane,
    I have been running it at 80:1. Absolutely no issues.
    Ran it on my 2015 te250.
    Great fuel economy and no engine issues.
    After start up, while running, guys behind you can barely tell you are running a 2 stroke.
    My cousin put over 200 hours on his 2015 250xc as an A enduro racer and also had no issues.
    I plan on running it in my 2017 te300 as well.
    Would not hesitate to recommend.
  15. Pedec Husqvarna
    Sask.Canada
    Amsoil dominater at 40-1 in my wr 165 with Lectron carb over 165 hours runs great. Did top end at 100 hours and rings were just in spec and piston looked great and no carbon build up. Also run it in my 250sx on a snowbike which is high demand riding and also so far compression has stayed the same. I also run 1/4 c-12 vp race gas in my mix not sure if that helps but both bike have compression over 200 psi so can not hurt.
    lankydoug likes this.
  16. PaulD Husqvarna
    Little Egg Harbor N.J.
    2010 wr250( sold)
    Triumph Sprint RS. Honda TRX300EX Be
    The outboard motor manufacturers had a 100-1 oil mix battle years ago. I think OMC started it then Merc jumped on board to keep pace. It was to reduce cost and spew less unburned oil out the exhaust. Dont remember any ill effects from it. Everyone has long since developed variable ratio oil injection systems that idle at 100-1 and go to 50-1 at higher speeds. Now its all direct injection that uses much less oil overall
    NCSteve and ohmygewd like this.
  17. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Never been keen to run my bikes anything higher than 60:1 on the 360 and 50:1 on the 250....you probably could run them @80:1 all day riding at 1/4-1/2 throttle but l also fear when you hit the fire trails you sudden go from 1/4 throttle to WFO...painful memories of seizures.
    Anyway, DI oil injection on the Beta is a marvel, a mate rode 6hrs with us and after two tanks all his bike used was like 10-15ml of oil:eek:
  18. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    19L(2 tanks) for 10-15ml of oil?!! That's a fair bit leaner than 100:1-like 1900:1!!!
  19. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Run what ya think you should. More oil was the norm back in the day for better ring seal under max RPM . Trying to run less seems the modern environmental thing to do. I run 36:1 on a 11 year old bike. The jetting is perfect for what I ride. I could run 50:1 just to say I did, but I'd have to screw around with jets. ME, I like to ride.
    robertaccio likes this.
  20. shawbagga Husqvarna
    None
    2018 Gasgas XC250
