ray_ray
Mini-Sponsor
5Wt sounds good! Only 2.5 wt go to after this .... my manual says 7.5wt front, 2.5wt rear ...
U can check UR front sag easily... I wish I had the number for a fully extended fork but I lost my HD and all my photos so I don't know for sure ... ... It was something like 11.75" .... U can take your sag reading from that ... Mine is probably only about an 1" (25mm) ... maybe too little but OK 4 now :0) ... I read where the number for sag on the front is 35mm +- 10mm ...
I was riding too far down in the stroke initially so I just moved the clip down I think and jacked my forks up in the stroke ... This is an easy change and if you don't move the clip too far, U can change it without even draining the oil out of the outer chambers ...
Good luck on the race and kick some butt$ but be safe
Here is a thread where the spring-rates \ pre-load are explained to some degree...It s sort of cool because it gives a method to set the pre-load that determines if your current spring rate is correct :0 )
http://www.cafehusky.com/forums/showthread.php?t=8094
