09 510 TE throttle block
Discussion in '4 Stroke' started by paramedicmeyer, Apr 9, 2009.
  1. paramedicmeyer Husqvarna
    Fort Bragg CA
    Just got my new 09 510 te. At the dealer they said I could remove the throttle block but what they described looks nothing like what Im looking at. Also none of the other posts here look the same. Were there any changes from 08 to 09? Any help w/ pics would be helpful as bikes in general are new to me. Thanks
  2. WoodsChick Administrator
    Oakland, CA Miramonte, CA
    KTM, GasGas, Suzuki, Honda
    Welcome to CafeHusky, paramedicmeyer :cheers: My sister lives in Fort Bragg and it's pretty much dualsport heaven there :thumbsup:
    I don't know anything about throttle blocks (throttle stop?) but I'm sure someone here can/will help you.
    WoodsChick
  3. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    • Take a look at the FI system on the right side of the bike- under the tank-
    • see the throttle cable cover- there's an allen head bolt holding it on- take it off.
    • look at the throttle wheel- loosen the cables - take the cables off- or loose enough to get around them with a screw driver-
    • see the two Phillips head screws- they hold on the throttle stop plate- take them off- now take the plate off- put the two screws back in -
    • tighten the cables- so there's just a little slack- check that it returns well and adjust as needed- put the cover back on- then throw the throttle stop plate in a box.:thumbsup:
  4. SoCal_250 Husqvarna
    San Diego CA.
    I just bought an 09' SMR - noticed this throttle stop, the dealer will hopefully take all the restricted parts off.
  5. gearstace Husqvarna
    Idaho
    here is a pic
    here are some pictures of my 09' I just took off, I hope this works/helps.
  6. paramedicmeyer Husqvarna
    Fort Bragg CA
    could you repost that pic. it didnt come through
  7. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    With stop installed, circled.[IMG]
    With stop removed. HTH
  8. Coffee CH Owner
    Could someone confirm what year bikes those pics are relevant to?
    2008/2009 TEs?
  9. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    That's from my '08, bet '09s are the same or close enough to figure it out.
  10. Coffee CH Owner
    Well if we can establish some reasonably concrete information then you can start up a new thread and I can add a copy to the tech ref section cause the topic is going to come up again.
    You do want to see your name in lights don't you?
    Just noticed this thread is in the common topics section...
    common topics --->>> 4st.
  11. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Nah, just want to help somebody else much like your valve check video did for me. Haven't heard of any physical changes on the Mikuni throttle bodies between 08 and 09 so am ASSuming they're at least similar in configuration. :)
  12. HUSKYnXJnWI Husqvarna
    09TE450
    Yes- its the same as my 09TE450.
    I just gotta see Ioneater's name in lights. Coffee, See what you can do!:busted:
  13. paramedicmeyer Husqvarna
    Fort Bragg CA
    I can confirm that it's exactly the same as the 09 510 TE. Just pulled mine off and it's identical. No thanks to the smart dealer who told me it was on the opposite side. Could anybody comment on what to loosen to move the throttle caboe out of the way. At the tube or directly in the box?
  14. Coffee CH Owner
    That is what 'your name in lights' means - filing threads away to help the next person.
    Question - what does "HTH" mean in reference to the second pic?
    Done! Here is a new thread,
    http://www.cafehusky.com/forums/showthread.php?t=2592
    and I put a copy in the Tech Ref section. Just keep posting to this thread and someone a year from now will wake the other thread up if they have a question. This thread is a bit cluttered now.
    Thanks!
  15. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    I loosened the cables down at the throttle body by backing off the jamnuts and swagged it when retightening ensuring full throttle travel could be achieved.
    Coffee,
    HTH=Hope This Helps
  16. Coffee CH Owner
    LOL
    :lol:
    Yeah some of us are old... I'll go spell that out.
