Baddrapp
I just dismantled my cooling system to eliminate all the stock coolant. The stock coolant looked like dirty water. It was terrible, it did not even feel like coolant. As the coolant dried it would leave a dry chalk substance on everything.
Let me start with the temp. It was 92 degrees with exceptional high humidity for the dry desert region. I started the bike as I was putting the side panels back on. It ran for about 20 minutes without the fan kicking on. I thought I must have pinched or broke a fan wire. I double checked and could not find any reason why the fan was not turning on. The radiator felt hot but still no fan. I thought screw it and started working the throttle. It took about 5 minutes of working the throttle before the fan turned on.
The only thing I can think is it is transferring the heat more efficiently then the stock junk fluid.
