  • 2 Stroke Husqvarna Motorcycles Made In Austria - About 2014 & Newer
TE/TC Xplor 48 bleed
Xicobombas
My 17 Husky TE 250, has wp xplor 48 suspension.
When I try to bleed the forks by removing the top screw, only on the left one you hear the compressed air leaving, nothing is heard on the right one.
This means I have a leak on the right one ?
Not necessarily. But to be sure check the O-ring on the bleeder screw and see if it is damaged. Remember that on the Xplor forks, the Left side is responsible for Compression while the Right side is Rebound. With that in mind it's practical that you would only get air bleeding from the left or compression side.
