X-Lite starting issues
dougn
I thought I would add my 2 cents to all the x-lite electric starting issues. My weak starting issue turned out to be the relay. Before you buy a starter or change the gears, try shorting across the relay. It can develop a small resistance and robb voltage. Since the starter load is a very small resistance, the rest of the circuit must be in good shape so that the full voltage is seen across the starter
It in fact was the starter motor. I still wonder why it seemed to crank good once or twice. I did take the starter motor apart numerous times. Anyway with a new motor it cranks with authority
