Putting lights blinker etc on WR390
With ignition running off one winding (blue/black 14 ohms) goes fine.
the other winding white/yellow has about 0.6 ohms.
Each winding wire to earth gave, white 1.5 ohm and yellow 2 ohm?
I was intending to put white/yellow into 12V rectifier/regulator running standard lights.
Does anyone know the AC output from either white, yellow or both in ac volts. Don't want to go too high.
