125-200cc WR/TE Side stand bracket
robj
I’m trying to fabricate a bracket to mount a 2011 Husqvarna ally side stand onto a Husky CR125 frame.
Could anyone send me a straight on photo of the bracket without the stand mounted, so that I have a starting point reference to copy for fabrication.
If you have a frame lying around it would be great for me to find a pic.
Thanks!
Only thing I can find right now is this video I made years ago of my WR300 2010 when I installed the Lectron carb.
I was just repairing the side stand and that video was shot without it installed so you can have a little peak on the tab itself.
I is pretty simple, a thick steel plate from memory something like 8mm , but measure the gap on your kickstand and use something just a little bit thinner than that. I would cut it way longer on the frame side and then give it the round tip expected so you have plenty of welding area.
You also need a little 'T' tip for the spring, but you can also use something else like a round hook or something.
Thanks!
I don’t have one with the stand off but see if these are helpful, otherwise I’ll pull off the stand this weekend. 2013 WR125
Took a few photos for you today. 2012 WR150
