suprize
the scooter has done 5 years since i gave it a big resto and it has done sterling work. only minor issues have cropped up over time and i had got away with using lots of original parts in the resto (cables etc) but they have probably got to their use by date. the grips are going gooeey and the knock issuing from the motor just cant be ignored. the chain tensioner is in a box worn out and the rear roller is a skateboard wheel bodgied up at an event.
So i launched into it...strip the seat and tank off, airfilter out and radiater hoses removed then the exhaust (only 1 rubber still holding
) then i measured and looked and thought..."bugger!"
the head has to come off to get the pot off the studs... so popped that off, its clean as a whistle..how nice.
then i slipped the pot off the piston and removed that from the rod...all good.
cleaned stuff up and got the piston and bore measured...hmmm will need to go to 83mm to clean it up...(was the original bore!)
ran into a max piccy's issue..will re post with more pics
