Winter Maintenance Adivce
huskyista
Soon alot of us will be doing winter bike maintenance. If you can't grease your rear shock linkage via zerk fittings and you haven't checked them in a couple of years, you should service and grease them. Last winter, I serviced my shock linkage on my 09 TE 250. I got my answer as to why I could't get the rear to settle down in the rocks. The linkage had 6 badly rusted and binding bearings. This was after only 3 years and about 3k miles. I replaced them and lubed them with Marine Grease (thick and blue in color). This grease is water proof and can protect metal even when water is present. It won't wash out and is what should be used on off road motorcycles. My bearings will get water in them, but I'll bet they don't rust again.
Just did mine and was able to clean everything up, grease and replace only the lower shock bearing, which was totally fried and basically non functioning. I was experiencing a lot of slop. All better now. Would be happy to help with any questions that people have along the way. Was a new procedure for me and fairly easy with access to a bearing press.
