Which new springs for my TC450?
wildrider49
I am 220lbs with full gear on a stock 2006 TC450 with 50mm Shivers. I keep bottoming out on the front end. I have set the rear sag properly and turning is good too. Talking to Hall's, my stock springs are .48kg and he has .50kg and .52kg springs for me. I'm riding rough desert hardpack with large whoops and jumps. I'm thinking of going with the .52kg springs and maybe lowering the oil level 5mm-10mm. Think the .52 springs will be too harsh? Should I go with .50kg and raise the oil level?
Anyone got any suggestions?
--Tony
I'd get Race Tech springs. They come a bit short and with spacer washers to add preload. That way you could get the .52 Kg/mm springs and shim them as needed to get the sag you want.
