Which Iridium plug for 2010 TE310?
shilo020
Looking to replace stock spark plug CR8EB with Iridium. Is it CR8EIX or CR8EIB-10? Then re-gap to 0.027"
Will I need NGK racing cable and cap?
I believe the "b" in the stock CR8EB designates the cap on the spark lead/connection. Ie. The CR8E is the same plug but has a threaded cap instead of the pop on connector cap. Not sure what the X is but I assume the B would suggest it has the same cap as the stocker.
with the CR8EIX you have to use a "removable terminal nut" to use the stock wire and cap. Or you could get a new Cap for the CR8ix which would be for a "terminal stud"
I have been running the CR8EIB-10 in my 09TE450 since 2010. (stock size is also CR8Eb) -it uses the permanent terminal nut just like the CR8EB. BUT the gap is a little more.
Found the CR8EIX plug no problem at the local bike store. The terminal nut was another problem. Not at dealer or NAPA or PepBoys. But the guy at PepBoys pulled one off another plug for me. Cool! Will try it tonight. Got a Shorai battery too. Maybe my bike will start better.
The CR8EIX has a treaded top. It needs a terminal nut to use the stock wire. I believe the racing cable and cap come as a unit and matches the threaded top.
Got the new plug and battery installed. I think starts better. Will see more this weekend with long ride.
