where is the resistor for pu kit / ecu located
T_I_G_E_R
Hi everyone Im new here Just picked up a te 630 w 800 miles on it.. the prev owner had put a plug in the header where o2 sensor was.. can someone PLEASE PLEASE post pics of where the resistor should go so I can check to see if it was placed and PLEAASE post a pic of where the new ecu goes when My arrow kit comes in.. I will be very very grateful
Lift the fuel tank, it'll be fairly obvious. If the dash is not showing an error it has been done.
PS. What is it with the whiney BS post?
lol whiney post.. I am used to the Husaberg forum where you get no response usually.. strange group over there
Welcome TIGER. Did you sell the KLX351?
I think you'll like the 630. Very easy to work on. I suspect the Arrow ecu installs similar to a PC-V. It plugs into the fuel injector harness and one wire at the stock ecu. I velcro'd the PC-V to the side of the battery.
If you shine a light up under the tank you can see the resistor plug.
Thanks Dynobob. I love the TE630 so far.. I drove it 500 miles home from the dealer.. and loved it.. its far more comfortable than my Husaberg, and yea its got lots of room to work. I noticed the cam chain or something is ticking.. its normal>? I took the tensioner out and it seemed to be stuck.. I put the spring back in correctly and the ticking decreased a little but still sounds like a sewing machine
I am no expert, but i believe the bike will either not run or not run right without the resistor after the O2 sensor has been removed. And most likely also show a engine light.
It should be under the tank about half way more towards the left side on the bike.
Here's what it looks like. The white plug is what you are looking for. It will have a resistor at the end of it.
