dartyppyt
Thought I would start a thread on where to find parts that interchange alot cheaper.
This will help alot of us restore our old vintage bikes with alot less money.
Example.
For stainless steel cheese head screws.You know them ones with the round heads/slot to hold on the chain buffer pads, etc.... I size them up through FASTENAL. I bought several in different sizes/ lengths for under $10.
http://www.fastenal.com/web/product...ipcode=&filterByStore=&r=~|categoryl1:"600000
For heim joints in top eye of piggy back ohlins and both eyes in ohlins ITC's. I use part number GE12E through BEARINGS DIRECT. Currently they are $5.75 each.
http://bearingsdirect.com/GE..ES-Series-Metric-Plain-Ball-Bushing-Bearing.html
For Metric O rings (Swing arm, shock heims, etc.....) I use THE O-RING STORE. Last time I ordered swing arm o rings, they were $.50 each.
http://www.theoringstore.com/index....th=368&zenid=9b2212705d20383faca0e97855476e58
For crank seals, remove old seal/record info on seal (size and type) and contact METRIC SEALS, INC. Phone # (317) 896-3555 also, they have online catalog as well. Last time I price the ignition side seal, was like $10. They also have better than original seals, as well. Have fork seals, copper washers, and o rings. I even sized up kicker and shifter seals.
http://www.metric-seals.com/catalog/AdvancedWebPage.aspx?CategoryText1=Shaft Seals&SBCatPage=&FromPage=1&sbt=
These are just some ideas to get started and you may have some better resources at better prices.
Anything:
Tires (Especially 17 inchers)
Bearings
Cables
Magura Levers
Throttles
You name it put it down along with part number, size, contact info, website, brand and you name it.
Even if you find a sale on something.
Example.
Anything:
Bearings
Cables
Magura Levers
Throttles
