wheels swap???
Spindles? Ya mean hubs? And is this a educated guess, or are you pretty darn sure? Anyone else have info? Thanks for quick replys.
Its an educated guess, but the earlier models had cush drives on the rear wheel. Will need to take that into account when looking.
I think the internal hub diameter is different so need to check on that and get spacers or spindles that fit.
I ended up getting wheels off a later model TE to fit my 610SM.
There's brand new set of wheels going on ebay for about £650 for the TE Model.
I paid £350 for a second hand set with tyres, sprockets, and discs
The 02 rear should fit if you use the 11 outer spacers.
The 02 front should fit if you change bearings, seals, inner spacer and use the 11 outer spacer.
