Wheel Spacer Dust Covers -NEW!
Huskynoobee
CH Sponsor ZipTy Racing
Staff member
From the race shop to you. These revolutionary dust covers offer a simple solution to an all too common problem. Wheel spacers are there to keep the front wheel centered but they always want to jump out when you're trying to slide the axle in. They also seem to have a way of attracting dust and grit that wear both the spacer and the dust seal, and eventually the bearings.
PROBLEM SOLVED!
• Made of Derlin Plastic for precision, light weight, low friction, and durability
•Simple press fit that makes installation fast and easy
•Wheel swaps have never been this easy - keeps the spacers in place
•Keep dirt and grime away from your seals and bearings
•Fits all Husqvarna and KTM with the "small" 20mm axle
Only $19.95 a set
https://ziptyracing.com/products/ktm-husky-front-wheel-spacers-dust-cover
Not sure, they are made to snap on to the OEM KTM/Husky spacer. So depends on the OD and ID of the Beta/SWM spacers. We made these for the race bikes to test before sale. There are plans in the works to make other versions, so stay tuned.
