WHATS THE DIFFERENCE
The 82 has double sealed front forks{2 seals in each leg} and a different shaped combustion chamber cylinder head,and don't forget the blue plastic oil filler cap!
Weren't the wr cylinders black and the cr cylinders bare alumimum? I see this on the 83ish 250's?
81 models has a different RH side panel than do the 82. The 81 attachment screw is located near the upper shock mount. The 82 doesn't use a screw there but has one further back up by the muffler.
Also 81 WR's still had the skinny 35 mm forks. The 82 got the 40mm if I am not mistaken. 81 WR had old light unit whereas 82 had the white plastic integrated light number plate unit.
