What sag setting for the 449 ?
30-33% of overall suspension travel (which is 300mm), so 90-99mm with the rider on the bike, in full gear, feet off ground, stand up.
Race sag full gear 100-105mm on most surfaces, hard pack, rocky. 115-120mm for high speed sand, open desert. If you are using the stock damper stop, you can swap it out to get 10-20mm more travel.
Right, they use this as the starting point to fine tune from. Its worked well for me.
Good info but the CTS may play a roll here and might need some different setup. Just tossing that out there.
It doesnt seem to make as much difference with the sag as I first suspected it would....however it is easy to sit so far forward that you get bad readings....
......If you are using the stock damper stop, you can swap it out to get 10-20mm more travel.[/quote]
This is something I guess I missed. who makes the aftermarket stop?
