MikeDi
I'm posting this thread for anyone in the future that may or probably will run into the same issues so feel free to add what you know. I'm no expert, i'm a hack that loves to mess with machines.
My Husky was a total roach. it had been ridden hard for 18 years then stored basically in a barn.
The starting point of most restos should be thought out. I mean, based on your skills and budget, don't bite off more than you can swallow.
Anyway starting from scratch.
- Power wash the bike, Strip off the plastics.
- Take photos of the wiring, cable routing and anything else you will forget in 5 months.
- Pick up a parts diagram and manual. http://hva-factory.com/catalogue
- strip down bag and tag all parts, clean them ahead of time so they are ready to re-install or put them in a separate box for replacement
- before removing the engine drain the oil and fill the gear box with kerosene. this will unstick and clean the inside. remove the side covers, crack loose the main gear and flywheel while the engine is in the frame.
- remove the chain, save it so you can measure up the new one and save time. last step you're going to want to get this over with.
- Strip the bike down to the frame, remove the wheels, remove the hockey puck tires and check the rims for cracks in the seam. if it's cracked a little on each side, no big deal. Check the spokes. I polish the spokes using about 400 grit paper backed by packing tape like a shoe shine. Clean the hubs, get all the rust out of the brake drums. I like to restore the wheels when the frame is out to sand blast. Again it's a last step in re-assembly and by then you want to get it done and over with.
- Pipe and silencer: take apart the silencer, scotch brite and re-pack.
- Pipe, mine was rotten from mouse pi$$. had to chuck it.
- By the way, a 82 83 XC500 pipe does not fit a 83 430.
- Shocks: I've only built one set of Fox shocks and hated it. I sent mine to a buddy who like to restore shocks. It cost me some bucks but they are like new.
- Motor, Splitting the cases on my 250 was a first time event for me. If you take your time and invest in the right tools, it's not that difficult. Again, the right tools. Buy the right gasket set, don't skimp. Take your time and prep the gasket surfaces. I didn't and have some weepy areas. I rushed it like a dummy. Replace everything you can afford. Maybe other guys with more experience can chime in.
- Top end: I sent my cylinder to a quality shop for first over bore. the 430 needed it, the 250 didn't but I sent it anyway. All in with piston and bore it runs about $300. I won't have to do it again and i know it's right.
- Bottom end; crank and bearings were good, didn't mess with them. Big bucks if you do.
- replaced crank seals and bearings, I borrowed my buddies electric griddle to heat the case halves. I worked well. Froze the bearings of course. Cases on my 250 were rotten. had to find a matching replacement set.. Again Matching set of cases for any of you guys searching this site.
- Frame: you can do it yourself with aircraft stripper or sandblast if you have the equipment. I sent mine to a local shop for blast and powder coat.
- check the foot peg mounts for wear. lay a weld bead down and build them back up so they don't sag.
- Tip: degrease the frame before you send it for powder coat. Sandblasting just drives the grease into the metal. You will save them time and get a better quality paint job. Also check the frame for cracks under the seat stays. if the tail section is bent, which both of mine needed a tweak, then wedge it in a tree and rail on it! Make sure the powder coat company doesn't cover up your frame number. Write it down ahead of time...
- you may want to put old bolts in the holes that you don't want powder coated.
- NO your down tube is not bent! it's supposed to be that way to clear the head of the pipe.
- Re-plating hardware and pcs. I sent out my parts for plating. was worth it. You need to wire wheel everything and degrease beforehand. TIP: don't have your axles plated. Yeah, that was dumb. I had to grind off the plating.
