All 2st What happens if too little, or too much oil, is used on a 2st Husqvarna?
Coffee
CH Owner
Staff member
I know nothing about 2st Husqvarna.... if too little or too much oil is used - what symptoms are there?
Full disclosure: While my question pertains to a 2st Husqvarna, it is actually in regards to a 2st 61cc Husqvarna chain saw...
Too little oil - it will seem 'crisp' and responsive, very little smoke and then it seizes up!
Too much oil - lots of smoke, reluctant to rev and may foul the plug. Plug will look black and oily.
Dave
So you mean premx oil?
Yes. Sorry.
I know so little about 2sts that I forgot they probably have oil to lube the gearbox (maybe, I really don't know 2st)
The premix oil. If a 2st is supposed to have X:1 oil to gas used, and either .5X:1 or 2X:1 is used instead - what symptoms would the motor exhibit?
I fully realize that if too little oil is used that at some point the engine will lock up, but that is not what is happening.
Dave
And the exact opposite is happening. I did forget about the plug being a useful indicator on a 2st, I will check that next time.
I used to use 8oz to 1 gallon with some old pre-mix oil we had.. Went and bought new 'Ash-less' oil (whatever that is) - and it said for the same ratio to use 4oz per gallon :confused: . Sort of confused at this point because it is acting *very* rich and smoky, with almost no power.
I supposed after enough use the air filter should be cleaned :lol: , I will check that too.
Had to google oz to gallon, we're sort of metric here :-)
8oz to 1 gallon is 16:1 which seems quite rich.
4oz would be 32:1 which should be fine, depending on the quality of the oil you could probably even run at 40:1.
Dave
Make sure the chain isn't too tight. Happens a lot on new chain saw's of every brand, chain get's tight & it bog's.
P.S. I personally run 50:1 in both my chain saw & weedeater (after running a couple tankfuls of 30:1 breakin ratio when they were new)
Make sure the chain isn't too tight...
Definitely not too tight :lol: (if you 'saw' it, you would understand).
The saw is at least 30 years old. It is a friends, and he has always used 16:1. The bizarre thing is, there are 2 chain saws, and the other one (Poulin) is also acting up slightly, sort of in the same way - and that only started when I began using 32:1 ashless 2st oil... but I've been cutting a lot of wood so I will check the air filter & spark plug and report back (just cleared 1000 meters of dense woods).
Also check the inlet filter on the gas line which sits in the tank and that the spark arrestor screen in the muffler is clear.
I've got a nice Husqvarna chain saw. I'm learning a lot about 2 strokes and oil, jetting, and temperament. For motorcycles the mix ratio can be tuned to the riding style. On the pipe a lot (high revs) needs more oil in the fuel. Old guy slow trail riding like I do needs less oil in the fuel. Of course this means re-jetting.
Chain saws don't generally lug around in the trees, they scream right through them so 32:1 sounds good. Your chain saw doesn't have a transmission but there is another oil tank to fill. You're filling the bar oil tank, I hope.
All said I'm having a good time fiddling with and learning about 2 strokes. I'm hooked!
That's completely correct. People seem to have a hard time understanding that it works this way. Spooge and fouling is caused by unburnt mixture (typically through improper jetting), not by too much oil. More oil means less fuel. Less fuel means the engine runs leaner.
On my Stihl there is a spark arrestor screen in the exhaust. If you have one, I bet it's a black grimy mess, all clogged up. Remove the screen and clean it. You can use a torch and heat the screen until the carbon comes off.
The leaner oil mixture makes the engine run richer. try the 8oz to 1 gallon.
Ok, I will check the plug, air filter, exhaust, and try a bit more oil. The saws were left were I last used them, which is a bit of a hike/walk to get to.
