Weld a Pinhole in the Stator Cover
Jim S
Is it possible to weld the stator cover? I have a tiny crack. How much should that cost? A replacement cover is around $100.
JB Weld- works beautifully, and as it starts to take-off you can smooth and form it with a wet finger. If you have aluminum chunks from the crack (doesn't sound like you do) put them back in place.
get the regular pack of J-B Weld.
good luck.
If you decide to buy a new stator cover, don't forget the bearing. It isn't seen I the same diagram as the cover, but it is seen in the left crank case half diagram. In that view the stator cover is seen, but not identified.
