darkstarmoto
So I have a decent USB cable direct wired to the battery to run my GPS & charge my Iphone. Over this weekend I was running some slow single track in mid-state PA and the temps were mild/warm. I got some kinda "overcharging" warning on the phone and the GPS went into boot mode but would not go to map. I suspected maybe the splitter I was using or the USB cable. Checked the battery when I got home with bike running and was getting 14.7V pretty constant regardless of RPM. Battery with engine off was holding at 12.6V. End of USB cable showed 5.2V with engine running and at each outlet of splitter also showing same voltage 5.2V.
I'm kinda at a loss because all voltages are in spec and sitting in garage both the phone & GPS are now fine.
Is it possible if the voltage regulator/rectifier gets too hot it would allow more voltage to pass? I did have a set of saddle bags draped over the seat resting on that plastic panel, but not necessarily blocking the one vent to allow air to the reg.
EDIT: Since I saw it in other posts, my headlight isn't out and I'm running a 45W bulb. No real noticeable difference in voltage at battery in Low or High beam.
