Yep but I take all the seals off except the outside one so the oil can get at the bearings.When I pressed the bearings out, one had both seals on it and the one next to the pump seal had one seal.
I thought that was a little odd, is that what you meant Mike?
If you take that outside one off then oil will come out the waterpump overflow.
With just one seal the oil will leak out while the bike is on the sidestand and that is why there are 3 in yours.
Very important to use coolant premixed with deionized water. Coolant not specified as safe for aluminum will start the corrosion process all over again
