Water pump seal size?
Freaky
Hi all, think I have a water pump seal on its way out, very slight weep from the hole behind the pump. Does anyone know what size the seal is so I can pick one up from my local bearing and seal trade counter? It's a 2010 TE250 x-lite.
Thanks folks.
Sorry but I can't find my seal to get a measurement :(..
Not alot of help but make sure you are getting oil dripped from the rubber seal in the second pic that fits around the spark plug ... This seal prevents oil from dripping from that small hole behind the pump ..
Are you getting water in the engine oil?
Here is a pic of the WP seal ....
This rubber seal sitting around the plug and stops oil from dripping past it ..oil that passes this seal drains out the hole behind the WP housing ..
Thanks ray-ray, will check this out.
Its a funky design and without that seal, oil pours out that hole ... I'll look more for that seal.. I'm sure it is here somewhere because I know I purchased a couple extras as they are only 4-5 dollars from a Husky dealer ..
