patgas;6775 said:
pirelli tyre about 10 psi,forks pushed up through clamps,are you saying i need less rebound -,not sure exactly what speed (concentrating on keeping the front end up right)great on fire roads just unstable on anything uneven/rocky
Now we are getting somewhere.
1) Put the fork tubes flush with the top of the triple clamps. This will help stabilize things. Its amazing how 3--5mm higher or lower will affect the front end. Once you get the suspension dialed in, you can play around with lowering the fork tubes to speed up the turning, if needed.
2) I take it the bike is 'deflecting' off of rocks? You should be able to ride over a rock the size of a grapefruit and barely feel it. Your front suspension is to stiff. Less compression will help (you should have just enough compression to bottom out on the biggest jump you will ever ride), and slow down the rate the forks return up.
Most guys run with far to much compression, and far to fast rebound.
Go out to the garage, hold the front brake, and push down on the forks. Are they springing right back? Or are they slowly returning? Slow is good, unless you are a pro.
3) Write down, on a paper or sticker on the bike, the exact settings of compression and rebound you now have. Then start backing them down. If you get confused, things get worse, you can just go back to the stock settings and start over.
4) Huskys come with very stiff springs. It wouldnt surprise me if you need zero clicks of compression. In fact thats probably where you should start, and just focus on the rebound, adjusting until things get better.
You can get to the point where there is not enough rebound--meaning its so slow the fork never gets to be fully extended. This is called 'packing'. Check for it on downhills, where the weight is on the front of the fork, especially on downhill braking bumps. Adjust the rebound accordingly. If the bike is packing, it will feel very very stiff, and there will only be 4-6 or so inches of travel being used. you will then need adjust for a bit faster rebound.
Just some ideas for ya.
