Freaky
Hi all, did my first valve adjustment on 2010 TE250 Saturday after a check showed that both exhaust valves were 0.05 too tight, I must say it's a work of art inside that cam cover, everything is in miniature compared to most other Jap stuff!
So, re-shimmed with 1.6mm shims and took for a test ride, you really wouldn't think that .05mm would make any difference to performance but I can tell you it does, in the lower revs the bike fells so much more responsive and pulls higher gears better, also I never had any problems with starting but now it starts as soon as the button is pressed where before it may have taken a revolution or two. Anyway, well worth the hour it took in the shed, check your clearances guys, tiny adjustments make noticeable differences!!
