Valve clearance issue SMR511
philfy20
Hi there,
My bike went back to the dealer due to a leaking head gasket just after 2,500 Km's. They have replaced the gasket and started to put bike together however found issue with valve clearance and it is way off.
Clearance on the exhaust valves are fine however the inlet valves are way off. Clearance should be 0.1mm to 0.15mm however it is 1.25mm**************************************** Anyone have any suggestions as the dealer has no clue have even the got the husky dealer of Australia tech to have a look at it and doesn't have a clue. They are throwing up the suggestion of a brand new cylinder head!!!
Any help will be greatly appreciated as my bike has been out of action now for 6 weeks and just want to be able to ride again.
Note: Anyone with a husky in Melbourne, Australia do not take it to A1 motorcycles they have no idea on what they are doing and have really messed me around.
Shims are in as you know for this engine they are half balls for the intake. Got a call from the dealer then and is pretty sure I will be getting a brand new cylinder head as looks like the valve seat isn't right
Heard decent things about Road and River down in Geelong, most of the bigger joints just churn through bikes during services.
Hi there,
Clearance on the exhaust valves are fine however the inlet valves are way off. Clearance should be 0.1mm to 0.15mm however it is 1.25mm Anyone have any suggestions as the dealer has no clue have even the got the husky dealer of Australia tech to have a look at it and doesn't have a clue. They are throwing up the suggestion of a brand new cylinder head!!!
Was the bike running normally when you took it in?
It was running however it did feel under power when you opened up the throttle (which would make sense). The more i hear from other people about this I feel that has already been under powered since I have had it. Will hopefully get confirmation on what is going to happen by the end of the day but the mechanic is 90% sure to fix the issue a new cylinder head is needed
