Kenneth Webb
Livin' It Up!
As far as I know, my bike has never had the valves checked until now. The first owner didn't do it as he recalls. Mileage is 3700. Exhausts were at .229 and .203 Intakes were .127 and .102 I elected to adjust just the large clearance exhaust by going from the stock 2.15 shim to a 2.20. That should have taken the clearance down to around .180, but checking, I could still get my .203 feeler in there. I guess there is some simple math there as the feelers and the shims don't match up in their steps. At any rate, my exhausts are slightly on the big side now, but close together. Intakes are both in spec, but one is close to minimum. Increasing the clearance on that one would have put me out of spec on the big side. I generally prefer to be big rather than tight. Will button up the head tomorrow when I have some daylight to wrestle with the valve cover.
Getting the valve cover off was the most difficult part as the gasket wanted to stay on the cover. I pulled the shims out with my little magnet, and put them in with a bit of grease on my finger tip. It's tight in there! SilverBullet helped with advice on how to remove the clip spacer on the cam followers. Thanks!
