urgent help needed now
bhima
just picked up my new[ish] 2012 te250 with 2.9 hours on it.
after half an hours riding i stalled the bike and it wont start the starter just whirls and spins and does not engage.
when trying to kick start it makes alot of electrical noises very little compression and wont start
had a few bump starts in 2 and 3rd wouldnt start
[b4 i stalled i put it on mapping 2 and it splutted on mapping 2] i think i put it back on mapping 1
the dealer is a 2 hour drive away
thinking to return the bike and go for an old carb model!!
not happy
handled amazing! worried i couldnt get the front up and should of got a 310 however its still on a 40 back cog i trust it will lift with the 50 sprocket??
ive got a 05 510 a wr 250 and had 2 te 450s. no local dealers! had problems with dealers b4! this is from a new dealer
however im a husky man i think
any ideas ?
not happy
any ideas ?
Start with the flywheel key, seen alot of posts about the key shearing off. There's a starter gear on the flywheel that is supposed to spin free when it's running or when you kick it, sounds like it's stuck. I'm not sure that would keep it from running but mine is stuck at the moment and it won't start either.
Sweet! Easy fix. Wish we knew why it happened.
I have some possible suguestions as to why the key sheared
-the key was improperly hardened
-the bolt/nut that holds the rotor on was too loose
-the taper on the crank and the taper inside the rotor are not the same and don't fit together well
