Updated CDI and cam for 2010 TC250s
ray_ray
Mini-Sponsor
Going back and covering all the bases on this bike to decide where to continue with the starting issue ...
Does anyone know how to tell the old CDI and cams from the updated parts? Can anyone supply the part number of the updated CDI?
Here is mine : 8000A7032 -- CU7539 -- CDI box #
I've got the yellow-lettered bike ... Last 4 numerals on my steering head column are 0049 ...
Also, about the cams issue, some of the threads I've read here seem to indicate that some polishing(?) can be performed on your current cams to help with this starting issue?
I don't know the part number, but the outdated cam has a straight spring leg on the auto decompressor. The correct one has a slight bend in it. That teeny tiny little bend made an enormous difference in the possibility of kickstarting the bike. Here are some pics:
http://www.cafehusky.com/threads/my-hot-starting-issues-solved-2010-txc-250.18204/
I do remember reading about a guy that did some sort of cam lobe modification to his TC 250. I can't remember if it was to make it start easier, though.
My cams must be outdated then because I have the straight spring ....
I did make the bend in the spring a couple days ago and the bike started on 1-2 kicks that afternoon ...Thought it was fixed but the next day the bike returned to the > 10 kick saga again ... I'll be pulling the cap back off the head in the next day or so and I'll check it again ....
