txc450 wont start
fire1998
We have a txc 450 that died on us, to me the timing looks off, the chain gear is lined up, piston is at tdc on compression, but the marks on the cam gears are 1/2 a tooth high on each side, and the cam lobes are not pointing at the same angle towards the middle, they are off by a few degrees. The bike was running great for about 25 min. I don't see how the timing could be off but I've tried to adjust the cams but then they don't align with the cam chain gear. Any ideas? Am I looking at the wrong thing?
Was the bike running OK and then it just died?
If so, why would you suspect the cam timing?
A sudden die-off would normally be researched as an electrical short, a bad plug, bad gas, etc.
In your picture, is that the exhaust cam AFTER you moved it 1 tooth or before?
Any luck or good words on the outcome of your bike?
