The Gazzman
Please note the following:
1. Both years have the same crankshaft
2. Both years share the same gudgeon pin (16mm)
3. Both years share the same piston ring set but have different piston kits
So whats the difference? I found a good link for Pro-x 2012 part 01.6342.A which provides the specs. Refer
https://prox-usa.com/-01.6342.a
I then compared this with measurements for the original 2013 OEM piston with approx 200 hours on it. There is some carbon build-up on the top which makes it less than completely accurate.
Please see the diagram attached below. The main area of concern is D (the compression height?). It is hard to measure with a casting ridge in the way. The piston deck is approx 14.62mm thick. Once you go the edge of the gudgeon pin then D is closer to 16.00 mm, putting it almost 1mm higher.
Would someone verify this and try to contact pro-x locally to confirm the rationale for the non-inclusion of the 2013 model. I am trying to do this in Australia without interest.
Regards
The Gazzman
Regards
The Gazzman
