TXC 449 Autoclutch and Rear brake
65fastback
I am seriously considering going with the EFM Autoclutch for my 449. I had the Rekluse Zstart pro on my 07 450 and I liked the ability to override the autoclutch with the lever. From what I understand there will be no over ride with the EFM:-( so I was thinking I can use my clutch lever/master cylinder for a left hand rear brake set up. Has anyone done this mod? I think it should be pretty easy, just get a new line made up.
Anyone have any experience with the EFM on a 449 or 511? Any pros and cons?
Thanks
Happy Christmas
The EFM I had on my TE 250 had an over ride. If fact if had the light feeling very similar to the z-start pro. I couldn't tell the different in the feel of engagement or over ride between the 2.
I have both the left hand rear brake and the EFM for my TXC 511. I am having problems with the bike flaming out. I am ordering a JD tuner to help with that issue. It does not help any matter that I am hard on the throttle.
I love the EFM, I have Pictures if needed.
Pictures of the EFM
I can't help with the EFM but I have both of my Huskies setup with LHRB's using the stock clutch master cylinder (05 and 09), they work just fine. I don't know what the newer bikes use but with the older Magura's and the mineral oil they need to be totally pulled apart and cleaned very good before using brake fluid. And for those with brake lights, I used a 90 degree fitting and the brake pressure switch right at the master.
