TPS Connector Question
Fast1
I'm thinking my TPS (white connector) that plugs into the throttle body on my TE630 has become wet inside and it is causing related engines running issues.. popping,, backfiring ect.. I had this happen last year and was successful at drying it out with a hair dryer which resolved the problem.
Currently my hair dryer remedy is not working.
Question is:
Does the TE510 have the same/identical TPS connector? I'm think I should buy a used one from a TE510 wiring harness to resolve the issue but am unsure of the similarity.
Any help from you guys would be appreciated..
Yes silicone grease to seal out moisture. It won't conduct though so try not to get it on the actual connection point.
guys thanks for the comments and yes I have used dialectic grease on the perimeter of the o-ring.
If any knows about the similarity to the TE510 TPS plus please chime in...
