Top End Parts For 08 Te250
BigShooter
Where would be the best place to find a replacement head for a '08 TE250, or the parts to upgrade to a 310? I'm hoping that's not a "good question".
If I can't locate them, or find them at a reasonable price (yeah, ha ha, right?), then I can tell you EXACTLY where to find every other part you need for one.
My right side exhaust valve broke off at the transition of the head and stem, and did about what you would imagine a loose valve in your combustion chamber would do.
Part #8000B0394
HEAD ASSY CYLINDER
ITEM: #HHU-8000B0394
$1,119.99
google shows it for around €700+ which is a bit more than $800.
good luck.
I did see that but fairly certain that’s not complete with valves. The 4 valves are almost cost of head. Valve guides appear to be included though. Maybe I read it wrong but believe that’s the case.
you may be right; the parts diagram is slightly ambiguous. but the description says "cylinder head complete" in all languages BUT english. so I dunno. might be worth it finding out.
good luck.
Doesnt come with valves its kind of misleading my guides are cracked rest of head is fine but cant buy seperate valves are ridiculous price got it down to 950 gbp for bare head and valves so think its getting parted out
Has anyone ever had the guides replaced found out a part number for them? Are they different to any other valve guides!!!
