eldridge 216
so long story short, i went to replace my water pump and my entire water pump shaft fell out of place causing it to come completely out of time. i knew what had happened so instead of just sticking it back togather and trying to start it i got it to where i believed was top dead center and alligned all the markings on the gears to where they should be (so i thought) and turned it over very very slowly by hand and it locked up. i knew better than to keep trying to turn it over so im sure i didnt damage anything. i need to know if there is a marking on the flywheel or anywhere that shows top dead center and where timing gear, and cam gears should be facing or aligned to. there is white markings on all the gears, i believe the white markings on the cam gears shout be facing straght up, and the timing gear's marking is facing straight up in line with the marking on the head? but i could be totally wrong ive never been in a husky 4 stroke engine.
