Speaking with other riders with way more experience than me the other day and the conversation concluded that:
Husky and ktm's trail ridden in:
1. Non competition (roughly meaning the engine spends most of it's life below 10,000 rpm and almost all below 9,000, especially at constant speeds)
2. Oil changed every 250km or 5 to 7hrs. Minimum of semi synth oil
3. Air filter changed every ride or day if multiple day riding in non desert/ dust environment and more protection if you are.
4. Valve clearances always maintained within spec.
5. Drivetrain maintained at all times (clutch, sprockets and chain tension)
6. Fresh fuel 98 Ron and not made by Shell.
You can expect minimum 200hrs plus from a top end and double from the bottom. Ktm's will burn through valves quicker, maybe 120 hrs subject to fuel. Husky is rumored to strip gears on occasion, but rare.
You will get more niggly ancillary system issues than japanese brands, but the faults are generally a known item with an easy and cheap fix or precaution to deal with them.
Japanese water-cooled engines won't always get these sorts of hrs, especially Honda.
Are these reasonable statements when considering huskies?
