Tightening Torques clarification?!?!
ripnriding
So after my recent episode of overtorquing my aftermarket front axle nut, resulting in rounding it and awaiting some Easy outs for removal....opened up owners manual and need clarification on the following:
on page 258/259 of manual for TE 450:
Front Wheel axle fastening screw - 38ft/lb
Front Wheel axle - 104.8ft/lb
On page 245/255
Front wheel axle fastening screw - 7.7ft/lb ?!?!?!?!
Front Fork Leg fastening screw - 18.4 ft/lb
so.....which one should I be torquing the FRONT axle nut to?!?! Odd.....very....Odd.....I'm going to guess the 38 ft/lb considering I torqued to the 104.8 ft/lb...REAR axle should be torqued to the 104?? Thanks in advance
axle pinch bolts are low torque and 8 ft/lbs is plenty, the axle torque is good at 38.... Fork triple clamp pinch bolts should be no more than 15 on the top and 12 on the bottom.. lastly, the rear axle "can" be torqued to 104, but that is completely unnecessary.... 85 or so is plenty. The tool kit wrench that was provided would never get it torqued to 104 and if it was torqued to 104, you would never loosen it.
Thank-you DEMI!!! This will be printed and posted up in the garage. Thanks for simplifyiing this for me ;)
