bschlott
This is a fix to reduce/eliminate the slop between the throttle tube and the bars that plagues most of our bikes. Now, this isn't going to be as awesome as an Uptite or G2 throttle tube, but it is also much cheaper. Sorry, I don't have any pictures, however, this modification is pretty easy.
I bought some .010" teflon sheet/film from McMaster (http://www.mcmaster.com/#catalog/118/3601/=iqxuud ; part number 8569K18).
I cut a piece about 2.75" wide (the circumference of the bars where the throttle tube slides on) and trimmed it to the same length as the throttle tube. It is okay to cut it slightly smaller than needed, but try to get it close (you don't want it too big, though). Also, make sure to cut it short enough so that it isn't pinched by the throttle cable perch. You want this piece of film to be able to slide freely under the throttle tube. I also rounded the corners of the rectangular sheet to keep them from catching on anything.
-Remove the throttle tube
-Dust the bars with some powdered graphite or similar (throttle tube area)
-Place the teflon film on the bars
-Slide the throttle tube over the piece of teflon
-Reattach the throttle tube assembly, make sure not to clamp down on the teflon sheet with the cable perch
This mod greatly reduced the slop in between the tube and the bars; the tube still moves freely on the tube (due to the teflon/graphite).
The sheet is about $6 + shipping. If you are already ordering something from McMaster, tack this on to your order. Not sure how much shipping is for just this item, but it can't be very much.
Hope somebody else finds this useful!
