Thread Title...2012 te449 hard starting
taylor te449
i have a new 2012 te449 and it starts good when cold but as soon as it has run for a while it is extremely hard to start.Had it back to the dealer and they have no idea as to what it is. Any one have any ideas ?
Need more descriptions as to what "hard to start" means. Does it not crank well? Does it stop on the compression stroke? Does it crank good but doesn't fire? Have you tried using the manual decomp lever if you have one? Have you tried cracking the throttle open a little when trying to start it hot?
there is a large brass screw on the left side of the throttle body.i think they call it the air by pass screw.it also has an effect on the idle speed.try turning it in some.i have seen that help.dan
You don't have an ignition key on the 2012 bikes so doing a TPS restart will need to be done by the dealer. Failing that, if you hold the throttle part open it should fire up, but on a very small turn of the throttle whilst pressing the starter and have the bike in neutral. I think you can by the ignition key and wiring for your bike its something i'd consider.
yep this works for me, just a touch of throtle
Thanks for the replies. The bike is back at the Husky dealer. Yes the bike fires ok when cold but even when it runs for a couple of minutes and stop it then it wont start.Yes it does crank ok and still no fire.I have tried to use a little throttle but it just has a compression lock. It did have a code on it 102 on the dash when it cranks but only seen once. It is frustrating and when you are in the middle of the track and it wont fire i get Ped off. IF ANYONE HAS ANY IDEAS IT WOULD BE APPRECIATED
I just bought a TE 449 and went for my first ride on Sunday and its doing the same thing.
Turn idle speed up a little. On my 2011 when its cold it starts fine but when its hot and the fan is running it affects the running. Only an idea.
make sure your in neutral my ,te don't start in gear it will just crank , on less the bike warm then it start in gear fine
